1360
WDM - Menu Item Style not updating when cssClass set clientside
I am attempting to change the style (cssClass) of menu items via JavaScript. I can get a particular menu item and enable/disable it successfully. However to higlight the fact that a menu item has become enabled i wish to change the cssClass so that the background and font style changes. Here is my client code:
var mm = $IG.WebDataMenu.find(mmName);  // Get the MainMenu on the master page
var items = mm.getItems();   // Get the Menu items
var i2 = items.getItem(2);   // get the 3rd item on the menu
i2.set_enabled(true);        // Enable it
i2.cssClass = "menuNAV";     // re-style it
However the change of style does not appear. This type of operation used to work OK with UltraWebMenu items.
The change does take place if I perform a PostBack to the server and overwrite the style in C# but then I get screen flicker etc.
What am I doing wrong?
(Ancillary question: I'm not familiar with AJAX and can find no detailed (or simple for that matter) explanation of how the IG controls use it. How difficult is it to perform an AJAX-style postback from JavaScript to the server that does not repaint the entire display? I'm thinking that I might be able to solve this issue by doing an Ajax-postback to the server and get it to update the menu that way.)
Kind regards
Paul
IG ASP.NET 10.3
VS 2010
CLR 4
