1370
WHDG don't expand if Initial depth = 0
I'm testing infragistics controls since 2/3 weeks and each time I'm trying something some wierd behaviors happen.
I've converted a VS2008 project in VS2010. I added an aspx page with master.
In master page I put  ScriptManager + UpdatePanel
in page I put WHDG like others times :
<ig:WebHierarchicalDataGrid ID="hdgTest" DataMember="BATCH" runat="server"         Height="100%" DataKeyFields="TxtNomChaine" AutoGenerateBands="false"         AutoGenerateColumns="true" Width="100%" InitialDataBindDepth="0" InitialExpandDepth="0"  >
       <Bands>
            <ig:Band Key="test" DataMember="LOGS" AutoGenerateColumns="true" DataKeyFields="TxtNomChaine">
            <Behaviors >
                    <ig:Paging PagerAppearance="Bottom" PageSize="10" Enabled="true" />
            </Behaviors>
            </ig:Band>
        </Bands>
    </ig:WebHierarchicalDataGrid>
and the Page Load
protected void Page_Load(object sender, EventArgs e)
{ if (!IsPostBack) { dsLogs = AccessLogs.Get(true, DateTime.Now); }
hdgTest.DataSource = dsLogs; }
2 problems :
1 ) if I set InitialDataBindDepth to 1 and InitialExpandDepth to 1 I'll see all rows like I want and Extend/collapse work but if I don't set Depth properties, the Extand button does a post back  but nothing happens
2) Paging is not working : Javascript error  "Object is null or not referenced"
