I am seeing the ViewState size continually grow on postbacks when I am not doing anything even related to the grid (just clicking an asp.net button and causing postbacks). I do not see the same behavior from the ASP.Net datagrid. I've attached the project I'm using to test this
Hi venkatp,
You should probably download the latest Service Release as you still have the RTM. That will not have the fix since it was found in that version.
regards,David Young
Could you please update if this has been fixed in any service release? I am experiencing the same issue with 10.3.20103.1013
Hello jferrin,
i wanted to inform you that I have logged this issue and the fix will be available in the next service release.
Please let me know if you have further questions.
Thank you for the sample attached.
I was able to reproduce the issue with the last service release of 10.3
I will investigate this and I will contact you later with more information.
Let me know if you have further questions.
