Is infragistics 2008 is compatable to infragistics 2007 version?Any one please suggest the backward compatability of infragistics 2008 version?Thank you very much in advance.
We do try to maintain compatibility between different volumes of our controls. However, things do change between volumes and certain features and properties in newer versions may not be available/exist in older versions. You can refer to the "What's New" section in our documentation for any featues that were added for each volume. In that sectionof the help, you can also review any breaking changes in that specified version. Below are some links to the 2008 Volume 1 "What's New" section where you can review any changes that may affect you.
Windows Forms:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.1/CLR2.0/html/Win_Whats_New.html
ASP.NET:
http://help.infragistics.com/Help/NetAdvantage/NET/2008.1/CLR2.0/html/Web_Whats_New.html
Note: In the revision history section of "What's New" you can track changes all the way back to NetAdvantage 2004 Volume 3.
