265
Issues with placing mouse cursor at text end when having huge data inside webhtmleditor
We are having issues while clicking using mouse at the text end of webhtmleditor control, especially when control is loaded with huge html data.
I have tried using javascript to set cursor position to text end on webhtmleditor focusin event but it alwasy gives me error at the following line [text.createTextRange(); It says undefined], but if i use this with normal textbox it works fine.
I tried different properties of text range, nothing seems to work with this control. Please suggest if u have any better solution
function SetCursorToTextEnd()
        var editor = iged_getById('<%=panelTo.ClientID%>');
        var text = editor._ie ? editor._elem : editor._doc().body;
        //alert(text.innerText);
        if (text != null && text.innerText.length > 0)
            //if (text.createTextRange)
                var FieldRange = text.createTextRange();
                FieldRange.moveStart('character', text.innerText.length);
                //FieldRange.moveEnd('character', text.innerText.length);
                FieldRange.collapse();
                FieldRange.select();
We are populating SPAN Html controls inside webhtmleditor.
example: webHtmlEditor1.Text = "<span id='I_1' title='Select to Delete.' contentEditable='false' unselectable='true' style='color:#00589F'>Dummy 1</span>;"; etc...
