I have a UltraWebGrid in an UpdatePanel but is not working. Whenever i click on the trigger button, it only bind the dataset header to the UltraWebGrid but not with any rows of data. Here are part of my code, please if anyone know how to solve it.
<asp:ScriptManager ID="ScriptManager1" runat="server"></asp:ScriptManager><asp:UpdatePanel ID="UpdatePanel1" runat="server" UpdateMode="Always"><ContentTemplate><igtbl:UltraWebGrid id="gvResult" runat="server" width="157%" Browser="Xml" OnInitializeLayout="UltraWebGrid1_InitializeLayout" OnInitializeDataSource="UltraWebGrid1_InitializeDataSource" Height="111%"></igtbl:UltraWebGrid></ContentTemplate> <Triggers><asp:AsyncPostBackTrigger ControlID="btnProcess" /></Triggers></asp:UpdatePanel>
is anyone faced this before? The update panel work well if I just put a normal asp label inside.
Now it able to bind only Header inside, but not any rows of data.
Thanks.
Why there is no answer here?
I'm facing the same problem... and i'm having trouble to find a solution to fix this problem.
Yes.. It does bind normally and able to apply the style I applied on it. But after added UpdatePanel, it only show header but without any data and the style I'm applying on it is not working as well..
Do you have any idea ? Thanks.
If you remove the update panel, does it bind normally with a full postback?
