225
UltraWebGrid and date format when editing cells
I am using the Infragistics4.WebUI.UltraWebGrid.v10.2, Version=10.2.20102.1011. The grid is bound to a datasource. Some of the data that comes out of the database is in the DateTime format. The database is Sql Server 2008.
The grid I am using allows for Insert/Update. It also lets you Insert/Update the columns containing the date and time. The UltraGridColumns that contain the date and time are set up with Format="dd/MM/yyyy" so that only the day, month and year are visible to the user.
When the user clicks in the date cell, the cell enters edit mode. At this point, the "dd/MM/yyyy" format is lost. The date comes out looking something like "Fri Jan 01 2010 00:00:00 GMT+1100 (AUS Eastern Daylight Time)" instead of "01/01/2010".
How can the UltraGridColumn be set up in a way that the format of the date and time is always "dd/MM/yyyy", even when the user is editing the cell?
