1025
Jquery and webDropDown
I'm writing some common javascript code for navigating away from the page.
i wrote the code on window.onbeforeclose() event this code is executed when i click on the webdropdown button
to open the list of items while it should not call this event.
to come over this problem I tryied to set some class on the controls where i dont wnat this event to fire
but the jQuery addClass does not work with infragistic controls and hasClass always returns null
what can i do to identify the controls in jQuery and code accordinglly whatever solution u suggest should be applicable to all the
controls with set and get as i want to set some property and then check it again on Onbeforeclose() event and if the property is set i wount fire that
code. The best solution will be if the dropdown not fire the OnBeforeClose event.
