75
Multiple Bands Hierarchy Sample
So on your ASP.Net samples website you have the "WebHierarchicalDataGrid -Multiple Bands Hierarchy" example, which I've used as the starting point for one of my own projects.
However, there seems to be an easily reproducible problem with your sample (and with my project that's is based on it):
1.  Expand and collapse the row with "Employee ID" of 1 about four times.  End with the row collapsed.
2.  Expand and collapse the row with "Employee ID" of 4 about four times.  End with the row collapsed.
3.  Return to row 1.  Expand it.  Note that it thinks for a bit, and then pops out to the expanded state.
4. Try to collapse row 1.  Note that it will not collapse.
So, what would be the best way to get around this problem?
Thanks!
  • 49378
    Hi harmonk00,
    The issue you are describing occurs when the Expand Animations of the grid are enabled. There is a development process in progress for that matter with ID : 84992.
    Until this behavior is resolved I would suggest disabling the expand animations on your WHDG.
    Please contact me if you need further assistance.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
