190
UltraWebGrid and Checkboxes
I have an UltraWebGrid that is bound to a sql data source through the code behind. I have also added a check box column through the code behind but don't know how to set the checked property based on a value of another column in the same row.
Any Ideas?
My sample would by a column called "First" which has a value of true or false. If the value on a particular row is true, then the checkbox on that row needs to be checked.
Thanks for the help!
