645
Create mulitple GraphPanes in the WebChart
My company just recently purchase infragistic tool.
I am using igchart:UltraChart to create a graph
Is there a way to create mulitple graph panes (different graph) in the Master Pane.
I want to create different ration for each panl, Can I do that.
I want to create the X-axis as date.
Could you please point me to some example.
  • 3255
    Suggested Answer
    posted in reply to Tung
    Hi Ted,
    I have used the code snippets from this tutorial http://help.infragistics.com/NetAdvantage/ASPNET/2010.3/CLR4.0/?page=Chart_Creating_a_Composite_Chart_in_Code_Part_1_of_2.html and http://help.infragistics.com/NetAdvantage/ASPNET/2010.3/CLR4.0/?page=Chart_Creating_a_Composite_Chart_in_Code_Part_2_of_2.html
    to build the following sample:
                ultrachart1.ChartType = ChartType.Composite;
                ChartArea myChartArea = new ChartArea();
                myChartArea.Bounds = new Rectangle(0, 0, 100, 50);
                myChartArea.BoundsMeasureType = MeasureType.Percentage;
                ultrachart1.CompositeChart.ChartAreas.Add(myChartArea);
                AxisItem axisX = new AxisItem();
                axisX.OrientationType = AxisNumber.X_Axis;
                axisX.DataType = AxisDataType.String;
                axisX.SetLabelAxisType = SetLabelAxisType.GroupBySeries;
                axisX.Labels.ItemFormatString = "<ITEM_LABEL>";
                axisX.Labels.Orientation = TextOrientation.VerticalLeftFacing;
                AxisItem axisY = new AxisItem();
                axisY.OrientationType = AxisNumber.Y_Axis;
                axisY.DataType = AxisDataType.Numeric;
                axisY.Labels.ItemFormatString = "<DATA_VALUE:0.#>";
                myChartArea.Axes.Add(axisX);
                myChartArea.Axes.Add(axisY);
                NumericSeries seriesA = GetNumericSeriesBound();
                NumericSeries seriesB = GetNumericSeriesUnBound();
                ultrachart1.CompositeChart.Series.Add(seriesA);
                ultrachart1.CompositeChart.Series.Add(seriesB);
                ChartLayerAppearance myColumnLayer = new ChartLayerAppearance();
                myColumnLayer.ChartType = ChartType.ColumnChart;
                myColumnLayer.ChartArea = myChartArea;
                myColumnLayer.AxisX = axisX;
                myColumnLayer.AxisY = axisY;
                myColumnLayer.Series.Add(seriesA);
                myColumnLayer.Series.Add(seriesB);
                ultrachart1.CompositeChart.ChartLayers.Add(myColumnLayer);
                //chart 2
                ChartArea myChartArea2 = new ChartArea();
                myChartArea2.Bounds = new Rectangle(0,50, 100, 50);
                myChartArea2.BoundsMeasureType = MeasureType.Percentage;
                ultrachart1.CompositeChart.ChartAreas.Add(myChartArea2);
                AxisItem axisX2 = new AxisItem();
                axisX2.OrientationType = AxisNumber.X_Axis;
                axisX2.DataType = AxisDataType.Numeric;
                axisX2.Labels.ItemFormatString = "<DATA_VALUE:##.##>";
                axisX2.Extent = 30;
                myChartArea2.Axes.Add(axisX2);
                myChartArea2.Axes.Add(axisY);
                XYSeries seriesC = GetXYSeriesBound();
                XYSeries seriesD = GetXYSeriesUnBound();
                ultrachart1.CompositeChart.Series.Add(seriesC);
                ultrachart1.CompositeChart.Series.Add(seriesD);
                // Customize the series colors.
                seriesC.PEs.Add(new PaintElement(Color.Green));
                seriesD.PEs.Add(new PaintElement(Color.Blue));
                ChartLayerAppearance myScatterLayer = new ChartLayerAppearance();
                myScatterLayer.ChartType = ChartType.ScatterChart;
                ((ScatterChartAppearance)myScatterLayer.ChartTypeAppearance).ConnectWithLines = true;
                myScatterLayer.ChartArea = myChartArea2;
                myScatterLayer.AxisX = axisX2;
                myScatterLayer.AxisY = axisY;
                myScatterLayer.Series.Add(seriesC);
                myScatterLayer.Series.Add(seriesD);
                ultrachart1.CompositeChart.ChartLayers.Add(myScatterLayer);
    And the following helper methods:
     private static XYSeries GetXYSeriesBound()
      XYSeries series = new XYSeries();
      series.Label = "Series C";
      // this code populates the series from an external data source
      DataTable table = GetData();
      series.Data.DataSource = table;
      series.Data.LabelColumn = "Label Column";
      series.Data.ValueXColumn = "Value Column";
      series.Data.ValueYColumn = "Another Value Column";
      return series;
     private static XYSeries GetXYSeriesUnBound()
      series.Label = "Series D";
      // this code populates the series using unbound data
      series.Points.Add(new XYDataPoint(1.0, 1.0, "Point A", false));
      series.Points.Add(new XYDataPoint(2.0, 2.0, "Point B", false));
      series.Points.Add(new XYDataPoint(3.0, 3.0, "Point C", false));
      series.Points.Add(new XYDataPoint(4.0, 4.0, "Point D", false));
      series.Points.Add(new XYDataPoint(5.0, 5.0, "Point E", false));
      return series;
     private static DataTable GetData()
      DataTable table = new DataTable();
      table.Columns.Add("Label Column", typeof(string));
      table.Columns.Add("Value Column", typeof(double));
      table.Columns.Add("Another Value Column", typeof(double));
      table.Rows.Add(new object[] { "Point A", 1.0, 3.0 });
      table.Rows.Add(new object[] { "Point B", 2.0, 2.0 });
      table.Rows.Add(new object[] { "Point C", 3.0, 1.0 });
      table.Rows.Add(new object[] { "Point D", 4.0, 2.0 });
      table.Rows.Add(new object[] { "Point E", 5.0, 3.0 });
      return table;
     private static NumericSeries GetNumericSeriesBound()
      NumericSeries series = new NumericSeries();
      series.Label = "Series A";
      series.Data.ValueColumn = "Value Column";
      return series;
     private static NumericSeries GetNumericSeriesUnBound()
      series.Label = "Series B";
      series.Points.Add(new NumericDataPoint(5.0, "Point A", false));
      series.Points.Add(new NumericDataPoint(4.0, "Point B", false));
      series.Points.Add(new NumericDataPoint(3.0, "Point C", false));
      series.Points.Add(new NumericDataPoint(2.0, "Point D", false));
      series.Points.Add(new NumericDataPoint(1.0, "Point E", false));
      return series;
    The result:
    Ivan Kotev
  • 3255
    Hi TedNguyen,
    Please take a look at this page for the list of 2D chart that you can create: http://samples.infragistics.com/2010.3/WebFeatureBrowser/contents.aspx?showCode=true&t=WebCharts/Gallery/TwoDChartGallery.aspx~srcview.aspx?path=../WebFeatureBrowserVB/WebCharts/Gallery/TwoDChartGallery.src~srcview.aspx?path=WebCharts/Gallery/TwoDChartGallery.src
    For Value 1 you can use the Gantt chart, for value 3 - take a look at theLine and Spline charts category.
    You can set ChartArea's position through chartAres's Bounds and BoundMeasureType properties.
    Please let me know if you have further questions.
    Ivan Kotev
  • 645
    posted in reply to [Infragistics] Ivan Kotev
    Thanks, Ivan
    I want to create something this
    The Value 1 and 2 is one graph, the value 3 and line is another graph, all of them in one image
