3788
Problem to load javascript file
I have a UserControl1.ascx in this userControl, i have hosted another usercontrol
GridUserControl.ascx.
In GridUserControl has a grid with ClientEvent <ColumnMovingClientEvents HeaderDropped="WebDataGridView_HeaderDropped" />
i am loading UserControl1.ascx dynamically.
and adding it in a panel which is inside the UpdatePanel.
on adding it, i am getting the error
WebDataGridView_HeaderDropped should be a function,function name, or function text.
why is this error come while WebDataGridView_HeaderDropped function is already written
in the GridUserControl.ascx file?
  • 640
    Hi Mypost,
    As the error suggests the ColumnMovingClientEvents.HeaderDropped expects its value to be a globally defined JavaScript function name, JavaScript function or a script text(one that can be evaluated using eval()). Are you sure that the function WebDataGridView_HeaderDropped is defined before the place where the WebDataGrid is rendered?
    It would be helpful if you could provide some source code or a complete example.
    Angel Yordanov
