I have an image button for opening a Commments window. I would like to superimpose the number of comments on top of the image (Bad image to follow).
I know I can align the text to image for left/top/right etc. but is there an offset and will it work with a negative value?
jack
_________
| 3 |
Hi jaddington,
You may be able to achieve your requirement using the ImageTextSpacing property of the image button. In order to be able to provide more insight I would need some more clarification on the specifics of what you are trying to achieve.
Please do not hesitate to contact me if you require further assistance.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
