Hello all,
This is my dayview settings.Eventhough I set the height and width of the 'AllDayEventAreaStyles' ,
the scrollbar is not displayed .It takes the space of as many appointments and the hours area is displayed blurred.
Any help?
Hello Sri,
Thank you for submitting your inquiry to the Infragistics ASP.Net Forums. I tested the markup code you provided using NetAdvantage 2010 Volume 3 Build 1013 and the ScrollBar for the WebDayView displayed properly, (see the attached screenshot).
Which version of NetAdvantage are you working with?
Please let me know.
Sincerely,Mike D.Developer Support EngineerInfragisticswww.infragistics.com/support
Thanks for replying. I am using NetAdvantage version 10.3 and the styleName is Nautilus.
I have given you the screenshot wherein you can see the Allday event is more nearly 20 where the scrollbars are not displayed and overlaps with the below calendar view.
What build version of 10.3 are you working with?
Hello Mike,
Build version is also 10.3.
I am using Infragistics35.WebUI.WebSchedule.v10.3.dll for the webschedule control.
It says only 10.3 version.
Mike,
The example you have shown above is having only one appointment for a particular user.
I think if you try it with say 20 records for a user ,you can reproduce the issue with yours in the AllDayEvent area of the Day view.
I have tried with all these appointment styles and allday event styles.Nothing is working.Still the same problem. Is there any other parameter which could bring the scrollbars for this Alldayevent area.what is the parameter called ' CustomRules' in Alldayeventstyle and what are the values passed to this parameter. will this parameter fix the issue.
Any help?it is urgent.
thanks
<ig_sched:WebDayView VisibleDays="1" runat="server" EnableAppStyling="True"
ID="webDayView" WebScheduleInfoID="wsInfo"Height="388px" Width="100%" ActivityWidthMinimum="25" ActivityHeightMinimum="20">
<AppointmentStyle Height="20px" Width="20px" ></AppointmentStyle>
<AllDayEventStyle Height="20px" Width="20px" ></AllDayEventStyle>
</ig_sched:WebDayView>
I have opened a support request for your inquiry. In the support request, I will provide you a sample for your review.Please use the following link to log onto your account at Infragistics.Com: <https://ko.infragistics.com/Membership/MySupport.aspx>Once you are logged onto your account, go to My Support Activity to view the support request for this inquiry.
Thank you.
