I have a problem. The thing is that suppose if we sort a column and if I want to display the data in grid as it was there before the sorting (of column/s) in a button's client side click, then how can it be achieved? Is it possible? If so how? Any help will be highly appreciated.
I just want to revert the grid back to its state without sorting of data.
Thanks & regards,
Assyst
Hi Assyst,
It has been a while since your post, however in case you still need assistance I would be glad to help.
I would suggest that you use the ColumnSorting client-side event of the grid to implement your logic for removing the sorting. Here is some sample code for clearing the sorting when the column sorting is to be descending:
function WebDataGrid1_Sorting_ColumnSorting(sender, eventArgs) { if (eventArgs.get_sortDirection() == 2) { sender.get_behaviors().get_sorting().clear(); }}
Please contact me if you have any questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
