200
Production Installation
Witch is the correct way to install ig_common virtual directory and infragistics assemblies for netAdvantage asp.net 2010 vol 3 CLR 4?
Just copy paste or run the infragistic installer on the server?
  • 2501
    Hello Soporte,
    Thank you for submitting your inquiry to the Infragistics ASP.Net Forums.  If you are deploying your NetAdvantage ASP.NET application into an environment where you have control over the web server, then it is recommended that you create common directories for the JavaScript files and images that the NetAdvantage ASP.NET controls use.
    Creating these common directories offers several advantages including easier maintenance, better scalability and enabling side-by-side versions of the NetAdvantage ASP.NET toolset. Once these directories are created, any application that uses NetAdvantage ASP.NET controls can use the resources in them.
    The above information may be found in the Infragistics ASP.NET Online Help on Deploying Common Assests at the following link:
     <http://help.infragistics.com/NetAdvantage/ASPNET/2010.3/CLR4.0/?page=Deploying_Common_Assets.html>
    Please take a look at the information found in the above link and let me know if you have any further questions.
    Thank you.
    Sincerely,
    Mike D.
    Developer Support Engineer
    www.infragistics.com/support
