Is there a way to clip the 0-1 and 99-100 from the chart? To give the data more view surface. I tried range max and min but not successful.
James
Hello RodBillett,
I believe this can be accomplished by implementing the IRenderLabel interface to customize the Y axis - http://forums.infragistics.com/forums/p/61528/311378.aspx.
Would you all happen to have the sample code that generats a Y axis like this?
That was it. Here is the final code I ended up with.
Thanks, James
Did you also set RangeType property to Custom, or is it set to Automatic?
