Hi Please check the attached code snap shot...below
after binding source .....when i'm trying to hide the column with below line of code n ...i.m getting the error : Object reference not set to an instance of an object
_grdviewSearch.Columns[
"StartDate"].Hidden = true;
please let me know any of you have solution ?
Were you able to resolve your issue or do you need further assistance?
Valerie
Hi prasantkumar ,
The Columns collection will not contain any autogenerated columns. Only columns you have actually defined on the aspx or added from the code behind. Perhaps that will help.
regards,David Young
_grdviewSearch.Columns should have a number based index. If you use columns.fromkey, you can enter the column key.
Ed
