380
Javascript Error
Hi
When i have populated context menu on a webmenutree when i right click on the node i get a javacript error and its not consistant too
Please kindly take a look at the attached screen shot
Raghu
  • 3726
    could you attach your sample, so that I can debug. I guess there is some problem in the  get_styleElement(). Because as seen from code this._activeNode is checked for null or somehow, this._activeNode is not a with WebDataTree node object. Do you do any manipulation of the active node of the web data tree, like changing it from outside, by the sample code? Which version of the product are you using?
    Lubomir
