410
Changing ImageUrl property on client side
I am using a WebExplorerBar and I would like to change the ImageUrl property on the client side whenever an ItemClick event occurs.
Unfortunately, I don't find the adequate Client API method to change the ImageUrl (if it exists), can you indicate me how to do this?
I was expecting to do something like in the JS code below, but unfortunately this "set_imageurl" function does not seem to exist. What shoud I be doing?
<code>
 <ig:WebExplorerBar ID="WebExplorerBar1" GroupExpandBehavior="SingleExpanded" runat="server" Height="300px" Width="250px">
    <DataBindings>
      <ig:ExplorerBarItemBinding DataMember="RootMenuItem" TextField="Text" />
      <ig:ExplorerBarItemBinding DataMember="MenuItem" DefaultText=" " TextField="Text" ValueField="MenuItemIsSelected" TargetField="_blank" ToolTipField="Text" ImageUrlField="ImageUrl" />
    </DataBindings>
      <ClientEvents ItemClick="WebExplorerBar1_ItemClick" />
</ig:WebExplorerBar>
<script id="igClientScript" type="text/javascript">
function WebExplorerBar1_ItemClick(sender, eventArgs)
 ///<summary>
 ///</summary>
 ///<param name="sender" type="Infragistics.Web.UI.WebExplorerBar"></param>
 ///<param name="eventArgs" type="Infragistics.Web.UI.ExplorerBarEventArgs"></param>
 //Add code to handle your event here.
 var selectedItem = eventArgs.getExplorerBarItem();
 selectedItem.set_imageurl("../Images/NewIcon.gif");
 return;
</code>
Any hint will be very much appreciated,
G.
  • 8160
    Suggested Answer
    Hello greale ,
    this should be working:
     function WebExplorerBar1_ItemClick(sender, eventArgs) {
                var explorerBar = $find('<%= WebExplorerBar1.ClientID %>');
                var selectedItem = explorerBar.get_selectedItem();
                if ((selectedItem.get_parentItem()._node) != null) {
                    eventArgs.getExplorerBarItem().get_element(0).childNodes(0).childNodes(0).setAttribute("src", "./rss_icon.gif");
                Height="300px" Width="250px" GroupContentsHeight="">
                <Groups>
                    <ig:ExplorerBarGroup GroupContentsHeight="" Text="Group">
                        <Items>
                            <ig:ExplorerBarItem Text="Item" ImageUrl="./icon1.gif">
                            </ig:ExplorerBarItem>
                        </Items>
                    </ig:ExplorerBarGroup>
                </Groups>
                <DataBindings>
                </DataBindings>
    I Hope that this is going to help you
