110
How to get the active DataKey?
I have a simple WebDataGrid in the page with a TemplateDataField column, which wraps a "delete item" button as ImageButton. I found no answer on the forums or API how to get the current DataKey when using the delete button.
Here is my code:
<%@ Page Title="" Language="C#" MasterPageFile="~/AppMaster.Master" AutoEventWireup="true" CodeBehind="ProjectList.aspx.cs"
    Inherits="Web.Modules.Projects.ProjectList" %>
<%@ Register Assembly="Infragistics4.Web.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %>
<%@ Register Assembly="Infragistics35.WebUI.UltraWebGrid.v10.3, Version=10.3.20103.1013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
    Namespace="Infragistics.WebUI.UltraWebGrid" TagPrefix="ig" %>
<%@ MasterType VirtualPath="~/AppMaster.Master" %>
<asp:Content ID="headContent" ContentPlaceHolderID="headContentHolder" runat="server">
    <script type="text/javascript">
        function pageLoad(sender, args)
            $('input[name*="deleteItem"]').click(function ()
                if (window.confirm("Are you sure you want to delete this item?") == false)
                    return false;
                else
                    // HERE I NEED THE DATAKEY
                    var grid = $.find('<%=pageDataGrid.UniqueID %>');
                    var activeRow = grid.get_behaviors().get_activation().get_activeCell().get_row();
                    window.alert(activeRow.get_dataKey());
                    return false;
    </script>
</asp:Content>
<asp:Content ID="pageActionButtons" ContentPlaceHolderID="pageActionButtonsHolder" runat="server">
</asp:Content>
<asp:Content ID="pageContent" ContentPlaceHolderID="pageContentHolder" runat="server">
    <ig:WebDataGrid ID="pageDataGrid" runat="server" Height="80%" Width="95%" CssClass="grid" DataKeyFields="PRJ_ID" AutoGenerateColumns="false">
        <Columns>
            <ig:TemplateDataField Key="DeleteItem" Width="75px">
                <ItemTemplate>
                    <asp:ImageButton runat="server" ID="displayItem" AlternateText="Display" ImageUrl="~/Library/Resources/images/itemView.gif"
                        OnClientClick="" />
                    <asp:ImageButton runat="server" ID="editItem" AlternateText="Edit" ImageUrl="~/Library/Resources/images/itemEdit.gif"/>
                    <asp:ImageButton runat="server" ID="deleteItem" AlternateText="Delete" ImageUrl="~/Library/Resources/images/itemDelete.gif" />
                </ItemTemplate>
                <Header Text="Actions" Tooltip="Actions for items" />
            </ig:TemplateDataField>
            <ig:BoundDataField DataFieldName="PRJ_ID" Key="PRJ_ID" DataType="System.Int64" Width="10%">
                <Header Text="Id" Tooltip="Project Identifier" />
            </ig:BoundDataField>
            <ig:BoundDataField DataFieldName="DESCR" Key="DESCR" DataType="System.String">
                <Header Text="Name" Tooltip="Project name" />
        </Columns>
        <Behaviors>
            <ig:Paging PageSize="20" />
        </Behaviors>
    </ig:WebDataGrid>
</asp:Content>
Can anybody help on this?
