In my one asp.net project, I want to realize the function like GMail Drag Drop to Add Attachment in IE6 or IE7 , what can I do by using NetAdvantage controls?
Thanks!
Hi Peter,I want to do same, and I had go through the above article but still am unable to download the full source code. Do I download it from some other place? Please suggest.Thanks,Lakhan Singh
Hi damofeiying,
File Upload drag'n'drop functionality can be realised in browsers that support HTML5 so I do not believe your goal is realistic in this case. You might want to look for alternative solutions, for instance by using Silverlight to implement an upload feature for you implementation as described at:
http://blogs.infragistics.com/blogs/anton_staykov/archive/2010/04/28/implementing-simple-file-upload-using-silverlight-4-drag-amp-drop-feature-and-infragistics-compression-library.aspx
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
