195
DropDownProvider value field not returned until clicked
I have a WebDataGrid attached to a sqldatasource that displays several cells. One is a DropDownProvider that uses a name as a TextField and an id as a ValueField. Works great in row adding. Works great in edit mode as long as I click on the dropdown. If I don't click on the dropdown, the value returned is the name and not the ID.
It seems the translation doesn't take place until there is an actual click causing a dropdown action.
I can write a workaround, but I wanted to check first. Am I missing an obvious setting?
