145
WebTab -- Page content missing -- What am I missing?
OK. This one's got me baffled.
I'm working on a web app that enables a user to select a report, set the parameters, then view a SQL Server Reporting Services ReportViewer.
For some reason, I can't get anything to show on the tabs greater than Tab[1]! Not even straight text.
Code is as follows (shortened to keep the message a reasonable length):
  <ig:WebTab ID="mnuiQuery" runat="server" Width="100%" Height="600px" SelectedIndex="3">
<tabs>
  <ig:ContentTabItem runat="server" Text="Queries" ScrollBars="Hidden">
<Template>
<asp:Panel ID="pnlQueriesLeft" Height="600px" ScrollBars="Vertical" runat="server">
<asp:Label ID="lblAvailableQueries" Text="Available Queries" EnableViewState="false" BackColor="LightGray" Width="100%" runat="server" />
<br />
<asp:Button ID="btnExpandAll" runat="server" Text="Expand All" onclick="btnExpandAll_Click" />
</asp:Panel>
</Template>
 </ig:ContentTabItem>
 <ig:ContentTabItem runat="server" Text="Parameters" ScrollBars="Hidden">
 <Template>
 <asp:Label ID="lblReportTitle" runat="server" />
 <asp:Panel ID="pnlParametersLeft" Height="500px" runat="server" ScrollBars="Vertical">
 <asp:Label ID="lblSavedScenarios" Text="Saved Scenarios" EnableViewState="false" runat="server" />
 <br />
 <asp:GridView ID="grdSavedScenarios" runat="server" AllowSorting="True" AutoGenerateColumns="False" OnRowCommand="grdSavedScenarios_RowCommand" DataKeyNames="ScenarioID" SelectedRowStyle-BackColor="LightBlue" onsorting="grdSavedScenarios_Sorting" >
 <Columns>
 <asp:BoundField DataField="ScenarioID" Visible="False" ReadOnly="True" />
 <asp:BoundField DataField="ScenarioName" SortExpression="ScenarioName" HeaderText="Scenario Name" ReadOnly="true"/>
 <asp:BoundField DataField="CreatedDate" SortExpression="CreatedDate" HeaderText="Created" DataFormatString="{0:MM-dd-yyyy}" ReadOnly="true" />
 <asp:BoundField DataField="GeneratedDate" SortExpression="GeneratedDate" HeaderText="Generated" DataFormatString="{0:MM-dd-yyyy}" ReadOnly="true" />
 </Columns>
</asp:GridView>
 </asp:Panel>
 </Template>
<ig:ContentTabItem runat="server" Text="Results" ScrollBars="Hidden">
 <Template>
 <asp:Label ID="lblResults" Text="test" runat="server" />
 Now is the time for all good men to come to the aid of the party.
<rsweb:ReportViewer ID="rvViewer" runat="server" ProcessingMode="Remote" Width="485px" Height="390px" ZoomMode="PageWidth" ShowParameterPrompts="true">
 <ServerReport ReportServerUrl="http://localhost/reportserver" />
</rsweb:ReportViewer>
</Template>
<ig:ContentTabItem runat="server" Text="Test Tab">
 <Template>
 Now is the time for tests
</Template>
 </tabs>
 </ig:WebTab>
 When I run the app, nothing shows up in the third and fourth tabs ("Results" & "Test Tab"). What could I conceivably be missing?????
Michell
  • 145
    Wow! Do I feel stupid!!
    Turns out I was missing a close tag in adding a Literal Control. I had "<table", instead of "<table>".
    Sorry for the panic,
    Michell
