I am using UltraWebGrid and WebCombo in my web application these controls are not working properly in IE9. If i run my web site through the Microsoft Visual Studio then While selection change the WebCombo or select any row in the UltraWebGrid i am getting exceptions like
Please help and let me know what i have to do to fix this issues.
Normally if i host in IIS and run in other browser like IE7,IE8, Opera, Firefox ... then it is working properly but in IE9 not working properly.
I am attaching exception screen shots bellow.
We had to go to 2010.3 with the latest service pack (service pack dated like march or april 2011).
Hi everybody:
I'm having the same issue: "Unable to get value of the property 'init': object is null or undefined". I'm testing on IE 9 locally. I've tested in IE 8 and it works OK. I'm using Infragistics ASP NET controls version 10.2. Do you know if this version is supported in IE 9?
Sergio
Guys,
I have tried the latest Service Release and it works with IE9.
Version: 10.3.20.103.2134
You can select a row perfectly and I can establish which row a user has selected (in-code).
thanks. currently getting latest SR and will see if that does the trick. thanks.
Hi bostonmerlin,
Upgrading from one version to another will not necessarily do the trick. You need to have the latest build of the given version. You should run the latest Service Release for 10.3. If you are still seeing an error, it is possible there is something that has not been caught and fixed. In that case, the best bet is to contact developer support so that a bug can be submitted directly. You would then be notified when it is fixed.
-Dave
