I have a webdatatree and a dropdown in the same page.for dropdown SelectedIndexChanged event i am getting the following error
Microsoft JScript runtime error: Sys.InvalidOperationException: A control is already associated with the element.
Please help me.
I've tried today to put web data tree in an update panel and I've configured AnimationDuration="5000" and I was not able to reproduce this error you are having. Can you upload a sample that reproduces consistently the behavior?
Lubomir
i am using updatepanel and webdatamenu is not used in the page.
Are you using an update panel? Do you have a web data menu on the page as context menu for the web data tree? I've seen this error when control is placed in update panel and postback is done from the control. But for some reason the control haven't been disposed properly before doing the postback and it stays registered in the update panel's underlying structures. Please upload a sample to debug the control. If you have WebDataMenu inside the update panel upgrade to latest service release and this error would be gone.
Hope this helps.
ASP.NET Team Lead
