I try the TreeView control and I have a vertical-align problem with expand-image.
Exemple :
<ig1:WebDataTree ID="Tree" runat="server" DataSourceID="XmlData"><ItemTemplate><span><%# DataBinder.Eval(Container.DataItem, "Value")%></span></ItemTemplate></ig1:WebDataTree>
below, the "-" or "+" is not in the middle of text
I try to use style like vertical-align, text-align, padding or marging witheout good result.
How can i resolve this problem ?
Thank you in advance for your help
Petar,
Even i am facing the same issue with aligning the node text and image. It seems to be an issue with Web Data Tree.
Could you help me out. The fix you suggested does not seem to work.
http://ko.infragistics.com/community/forums/t/71817.aspx
Parthi
Hi SBGG,
It has been some time since your post, however in case you still need assistance I would be glad to help.
In this scenario I would suggest that you check what value is applied for line-height by the igdt_Node CSS class. Setting this to a large value may cause the look which you have described.
Please feel free to contact me if you have any questions.
Did you try CSS? Put a class on the item and then do something like
.className {vertical-align:middle;}
(totally untested, but hopefully it points you in the right direction)
