1055
Remove height offset when fixing column
I have a WebDataGrid. I am fixing a TemplateDataField column in code behind on init. After that I am getting a offset of unfixed columns and fixed colum. See picture.
How to resolve that issue?
  • 49378
    Hi Thomas,
    It has been a while since your post, however in case you are still having issues I would be glad to help.
    I have tried the setup you have described but so far am unable to replicate the issue. If you are applying custom styles to your other column you should ensure that the same style is also applied on your template field (just in case since you are adding it from the code-behind). In order to be able to provide more insight I would need to know your product version, and also to see your markup.
    Best Regards,
    Petar Ivanov
    Developer Support Engineer
    Infragistics, Inc.
