Hi - I am using Infragistics webtab (v 10.2) to move between two aspx pages and here is code snippet.
ig:WebTab ID="WebTab1" runat="server" Height="200px" Width="300px" EnableValidation="true" EnableViewState="false">
<Tabs><ig:ContentTabItem runat="server" Text="Tab 1" ContentUrl="Page1.aspx">
</ig:ContentTabItem>
<ig:ContentTabItem runat="server" Text="Tab 2" ContentUrl="Page2.aspx">
</ig:ContentTabItem></Tabs>
<PostBackOptions EnableLoadOnDemandUrl="true" EnableLoadOnDemand="true" EnableReloadingUnselectedTab="true" EnableAjax ="true"/>
<AutoPostBackFlags SelectedIndexChanged ="On"/>
</ig:WebTab>
Here is the issue I am facing -
When I move from Tab1 (Page1.aspx) to Tab2 (Page2.aspx) Page1.aspx is loaded as expected, but Page2.aspx is loaded twice.
Am I missing any settings?
Appreciated quick response.
Hi Preet919,
That is possible that you have different scenario compare to original report.
It would be great if you write simplest possible sample (aspx and aspx.cs files are enough), zip those files and attach within Options tab. Also provide exact steps to reproduce that issue.
The fix for this issue should have gone out a while ago. Could you provide me with some more information about your implementation? It is possible that you may be facing a new issue that wasn't covered by the fix for the previous issue.
Hello again,
I upgraded my Infragistics to the latest service release i.e. 11.1.20111.2158. And the above problem IS STILL NOT fixed!!!!
Can someone from Infragistcs please reply? I have to get my project out and I cannot go with this double post-backs!
Thanks.
I have Infragistics 11.1.20111.2064. The problem still exists. Is there a workaround to fix it?
Please let me know.
History in tfs shows that it was already merged into RELEASE branch. It means that it was already tested and verified. In most cases time between fixes and services releases take around 1-2 months. That was fixed less than a month ago. I guess, it should be available in next service release.
