75
UltraWebGrid 8.1 & WebCombo 8.1 not compatible with IE9 + Windows7
We have an asp.net website which uses Infragistics 2008 volume (version 8.1)
We are facing a problem on Windows 7 with IE9. We found that Webcombo (8.1) and UltraWebgrid(8.1) are not compatible with IE9 on Windows 7.
Issue
When user selects an item from combo list, the list is not closed and throwing an error.
with ultrawebgrid, unable to select the grid columns to enter the data.
you can repeat the webcombo issue , go to
https://ko.infragistics.com/samples/aspnet/data-grid/dropdown-editors
1.Select "Grid->WebCombo->WebCombo" sample.
2.Select and Item from the list it throws an error.
Enclosing the error file
Upgraded to Infragistics 2010 volume3
I have upgraded the project and all reference to Infragistics 2010 volume 3 still the problem exist.
How to resolve the issue?
Vijay
