110
WebDataTree node click event is not fired on the server side
Hi
We try to replace the old UltraWebTree (v5.3) By the new one WebDataTree (v10.3  for asp.net  frame work 3.5  )
But we notice  that  the node click event on the server side is not fired  as before with (v5.3)
Note :
1/ we take care to add  <AutoPostBackFlags NodeClick="On" /> .
2/ We use VS 2010  but our web forms application still  uses  the old fashion code behind model :
I mean juste aspx+ aspx.cs  files   and  no  aspx.designer.cs .
3/ We have also tried to catch the click event on the client side with (v10.3) and it works fine .
aspx  Form :
<form id="Form1" runat
="server">
<ig:WebScriptManager ID="WebScriptManager1" runat
="server">
</ig:WebScriptManager
<table id="Table1" cellspacing="0" cellpadding="0" width="100%" border
="0">
<tr
<td id="td" align="right" width="100%" style="height: 18px; background-image
: url(APP_THEMES/<%=Page.Theme%>/IMAGES/searchbg.JPG);">
<input type="image" id="Pin" onclick="CollapseShowPane('<%=Page.Theme%>');" src="APP_THEMES/<%=Page.Theme%>
/Images/ig_menuBlueLeft.GIF"
style="vertical-align: middle;"
</td
</tr
</table
<table id="Table2" cellspacing="0" cellpadding="0" width
="100%">
<tr
<td valign="top" id
="treetd">
<ig:WebDataTree ID="WebTree" runat="server" Width="100%" Height="100%"
DataSourceID
="XmlDataSourceForTree"
Style="float
:left"
InitialExpandDepth="1"
onnodeclick
="WebTree_NodeClick">
<DataBindings
<ig:DataTreeNodeBinding DataMember="Folder" KeyField="id" TextField="name" ValueField="FolderTypeId"
</DataBindings
</ig:WebDataTree
<asp:XmlDataSource ID="XmlDataSourceForTree" runat="server"></asp:XmlDataSource
</td
</tr
<tr><td> <asp:HiddenField id="lastSize" runat="server" /> </td></tr
</table
</form
aspx.cs :
we impements the event handler:
protected
void WebTree_NodeClick(object sender, Infragistics.Web.UI.NavigationControls.DataTreeNodeClickEventArgs
e)
