20
Moving ASP.NET solution
Hi.
We need to move an old ASP.NET 1.1 solution from a Win 2000 to a Win 2008 server.
The solution uses Infragistics NetAdvantage 2004 Vol. 1 (ASP.NET Only).
All .dll's are placed under the applications bin directory:
Infragistics.WebUI.Design.v1.dll  (1.0.20041.14)
Infragistics.WebUI.Shared.v2.dll  (2.0.20041.10)
Infragistics.WebUI.UltraWebGrid.v3.dll  (3.0.20041.1019)
Infragistics.WebUI.UltraWebTab.v2.1.dll  (2.1.20041.1013)
Infragistics.WebUI.WebDataInput.v1.dll  (1.0.20041.1016)
The oldest installation package I have in my archive is the NetAdvantage 2004 Vol. 3 (ASP.NET Only).
I have enable .NET Framework 1.1 on the server and installed Ifragistics NetAdvantage 2004 Vol. 3.
However all of the Infragistics controls are non responsive...
Do we need to install the correct same version as the asp.net solution uses, do we need to install Infragistics NetAdvatage at all? Do you have any suggestions to why the controls aren't working?
We can see the controls (Ultra Web Grids) placed inside tha tab controls, but they are none responsive.
Yours Sincerely
Christer Buschmann
  • 8607
    Hello Christer,
    Yes, the version used in the ASP.NET solution is the one that needs to be installed on the server.  So that means either version 4.1 should be installed on the server, or the ASP.NET solution should be upgraded to 4.3.
    Please note that versions 4.1 and 4.3 are no longer supported, and have not been tested on Windows Server 2008.  For more information, please see our Supported Environments page.
    If you have any questions about the 4.1 installers, I would recommend contacting Sales, as they would not be available from the website.
    Elizabeth Albert
    Localization Engineer
