1325
How to check that its multi sorting is happening inside wdg_ColumnSorting client side function?
Hi Team,
As I had implemented some additional functionalities, I need to check whether the ctrl key is pressed for multi sort so that I can determine the sort direction. So will it able to track down the ctrl key press event inside the client event "wdg_ColumnSorting(sender,e)". If so how can I achieve it in script inside thw wdg_ColumnSorting client side function.
i.e; in short I want to check that its multi sorting is happening (or ctrl key is pressed while its occurence) inside wdg_ColumnSorting client side function.
Any help in this direction will be highly appreciated. Hopes it is possible and expecting a reply in soon for this.
Please provide a reply as soon as possible.
Thanks & Regards,
Assyst
