After applying the latest service release dated 15 April, the "Landscape" paper orientation for exporting the WebDataGrid to PDF has no effect either by setting the property on the control or by setting it in code. The PDF document is generated in portrait orientation no matter what I try.
Service release applied. Working. Thank you Tsvetelina.
Hi Tsvetelina,
After applying the latest service release dated 17 May, the behaviour is still the same.
The "Landscape" paper orientation for exporting the WebDataGrid to PDF has no effect either by setting the property on the control or by setting it in code.
Hello Casper,
Thank you for reporting this.
I tested the behavior and it appears to be a new regression issue in the latest SR.
I created a new support ticket on your behalf : CAS-64385-GC9ML5
I will update you through the system.
