140
Node Checkstate not changing on postback
Hi Infragistics,
We have this problem where in we are repopulating the tree on postback with different checkstate on each node. The initial tree has different checkstate on each node. However, the checkstate seems not changing. It still loads the initial checkstate of each node. What is the fix for this?
Robert
  • 7566
    Hello Robert,
    I have created a support ticket on your behalf  to investigate the issue further. The support ticked ID is CAS-67678-ZZ8B8Y. I will update you with the details around the issue.
    Thank you for choosing Infragistics
    Sincerely,
    Georgi Sashev
    Developer Support Engineer
    Infragistics, Inc.
  • 3726
    Hi there,
    could you upload a sample web site, so that we can examine your code. If you have proprietary code you can contact developer support and give the sample to them. I think you probably are setting the check state too early and it is replaced by the inital control check state.
