This is used inside an update panel as well.
I cannot use SQL Datasource on asp markup. All connections are done manually.
My tbl returns data using one table with a recursive relationship on GroupID and UpGroupID for the structure.
However no data is showing in the tree?????
Thank you in advance. This is my first post and I have spent half a day trying to get this to work.
Page Load Event calls LoadGRTree()
Private Sub LoadGRTree()
'loads group tree
Dim objCmd As New SqlCommand
Dim objDA As New SqlDataAdapter
Dim tbl As New DataTable
Try
If objConnP6.State = ConnectionState.Closed Then
objConnP6.Open()
End If
objCmd = New SqlCommand("spGroupsGetAll", objConnP6)
objCmd.CommandType = CommandType.StoredProcedure
objCmd.Parameters.Add("@CustID", SqlDbType.Int)
objCmd.Parameters(0).Direction = ParameterDirection.Input
objCmd.Parameters(0).Value = CInt(Session("CustID"))
objDA = New SqlDataAdapter(objCmd)
tbl.Clear()
objDA.Fill(tbl)
If objConnP6.State = ConnectionState.Open Then
objConnP6.Close()
' Create the view
Dim view As New Infragistics.Web.UI.DataSourceControls.DataView()
' Set the required properties
view.DataSource = tbl
view.ID = "mainview"
Me.GRWebTreeData.DataViews.Add(view)
Dim dr As New Infragistics.Web.UI.DataSourceControls.DataRelation()
dr.ParentDataViewID = "mainview"
dr.ParentColumns = New String() {"GroupID"}
dr.ChildDataViewID = "mainview"
dr.ChildColumns = New String() {"UpGroupID"}
Me.GRWebTreeData.DataRelations.Add(dr)
Me.dtGRGroupsMain.DataSourceID = Me.GRWebTreeData.ID
Dim nodeBinding As New Infragistics.Web.UI.NavigationControls.DataTreeNodeBinding()
nodeBinding.DataMember = "mainview"
nodeBinding.TextField = "GroupName"
nodeBinding.ValueField = "GroupID"
Me.dtGRGroupsMain.DataBindings.Add(nodeBinding)
Me.dtGRGroupsMain.DataBind()
Catch ex As Exception
Throw ex
Finally
If Not objDA Is Nothing Then
objDA.Dispose()
If Not objCmd Is Nothing Then
objCmd.Dispose()
End Try
End Sub
Asp Markup:
<div id="divGroupsMain" runat="server" style="display:block; margin:0px; border:0px; height:60%;">
<asp:Table ID="tblGRMain" runat="server" style="text-align:left; background:Black; width:600px; height:100%;" >
<asp:TableRow>
<asp:TableCell Width="50%">
<ig:WebHierarchicalDataSource ID="GRWebTreeData" runat="server">
</ig:WebHierarchicalDataSource>
<ig:WebDataTree ID="dtGRGroupsMain" runat="server" Width="100%" Height="300px"
BackColor="White" EnableConnectorLines="True" AnimationEquationType="Linear" AnimationDuration="150" TabIndex="1" CssClass="ResizeControl">
</ig:WebDataTree>
</asp:TableCell>
<ig:WebDataGrid ID="grdGRGroupsMain" runat="server" Style="width:100%; height:300px; min-height:300px;" TabIndex="2">
</ig:WebDataGrid>
</asp:TableRow>
</asp:Table>
</div>
Sorry for the delay. I was on vacation. I ended up just loading the data tree manually using jquery and ajax.
Thank you for responding though.
Hi there,
Could you try and set different parents and child dataview IDs and the same parent and child columns in this code:
Let me know if this brings the data back. Set parents and child columns to be "GroupID" and the view IDs to differ.
