I have a problem with the WebDataGrid.
I want to implement a "are you sure"-question when a user clicks a cell / row.
In the case of a "Cancel" the click event should not be fired.
If "OK" has been clicked, the click should be fired and a new page will be opened.
I have this code in my aspx page:
<ig:WebDataGrid ID="grdCompanyList" runat="server" DataKeyFields="objectNo" DataSourceId="odsCompanyList" AutoGenerateColumns="false" StyleSetPath="~/Styles/Grids" CssClass="InfoOverviewGrid" StyleSetName="Claymation" ShowFooter="true" ClientEvents-Click="onClick">
and the javascript function looks like that:
function onClick(sender, eventArgs) { var continueSelect = confirm('Are you sure you want to select this object?!'); if (!continueSelect) eventArgs.set_cancel(true); } }
But the click is fired no matter if Cancel or OK has been selected.
What is the matter? Does it work at all this way? Whats missing?
Why is it always fired?
I would be glad about any help.
Hi tiger1x,
I'm not entirely sure if you can cancel a click event like that. But since you're doing it off of a row or cell, why don't you turn on selection or activation and use the active cell changed or cell/row selection changed client event. Then you could confirm in there and then manually fire off the navigation.
regards,
David Young
