I'm sure that this is a basic function of a dropdownlist but I am finding the CSOM very difficult to get to grips with but they may be down to my lack of knowledge of JavaScript/Ajax but there does seem to be a major lack of any clear documentation or samples.
I have a WebDialogWindow which contains a WebDropDown which is databound. I click a button on a grid to view the item on the grid using the WDW. What I want to do is to recover a text field (Name) from a column in the Grid (which I have done) and pre-select this name in the WebDropDown. Pretty standard stuff...
My code so far from lots of various posts is:-
oddlpersonnel.selectItem(holderName,
true, true );
Looks correct to me - I also tried set_selectItem just in case I needed the extra set_ but still no luck. The web page says the object does not support this property or method. I'm not sure I can call selectItem in this way (passing a string which is the displayed text in the DDL) but this doesn't work anyway.
Any suggestions please before I just revert to a standard asp:DropDownList
Hello cmdrew,you can use the following javascript to find and select item:
var ddl = $find('<%=WebDropDown1.ClientID %>'); //iterate through WebDropDown items for (i = 1; i < ddl.get_items().getLength(); i++) { var item = ddl.get_items().getItem(i); //Check if the item has text equal to "Beverages" //You can use item.get_value() to check values if (item.get_text() == "Beverages") { //select item item.select(); } }
