are there any known issues concering WebDialogWindow and Internet Explorer 9.0
Our WebDialogWindows don't show up if we use the browser IE 9. With Firefox and older version of Internet Explorer, no problem.
best regards
Andreas
Hi Andreas,
I tested WebDialogWindow under IE9 and it seems to work without problems.
Can you test dialog in a separate temporary webpage?If dialog fails with particular settings or particular layout, then it would be nice, if you provide a simple aspx, which can be used to reproduce misbehavior. Simple codes you my paste directly. Note: to avoid formatting problems you may copy/paste block of codes into a plain text editor like notepad or notepad++.If sample is more than 20-30 lines, then you may attach zipped file within Options tab.
