545
Events not firing correctly
Hello, I just started poking around with the ASP.net controls as a trial and I can't seem to get the active cell changed event to fire. I've gone through the documentation and found an example that should work and i've mimicked it as much as possible but I found that the example was calling a javascript function which was doing a PostBack event to get into the VB.net that would actually do what I need it to do. The starting tag and the columns are basically verbatim  from the example so I'm assuming they are correct.
