I am noticing that the grid seems to be firing previously fired event when the grid sits in and update panel. I have a WebDropDown defined as follows:
<ig:WebDropDown ID="wddTearSheetLevel" runat="server" Width="300px"
AutoPostBack="True" onselectionchanged="wddTearSheetLevel_SelectionChanged">
<Items>
<ig:DropDownItem Selected="False" Text="Security Level" Value="SEC_LEVEL">
</ig:DropDownItem>
<ig:DropDownItem Selected="False" Text="Peer Group" Value="PEER_GROUP">
<ig:DropDownItem Selected="False" Text="Security Classification"
Value="Q_SEC_CODE">
</Items>
</ig:WebDropDown>
Update Panel Trigger, which fires on the selection change of the dropdown.
<Triggers>
<asp:AsyncPostBackTrigger ControlID="wddTearSheetLevel" EventName="SelectionChanged" />
</Triggers>
If i change selection in the grid, the change gets posted just fine. When the new selectection come up and i decided to delete a row in the grid. The selection event get fired again....
what gives?
Hi mdelgado,
It has been some time since your post, however in case you still need assistance I would be glad to help.
I have tested the scenario with a 11.2 WebDropDown inside an update panel but am so far unable to replicate the behavior you describe. I would need more information about the grid that you are using which is somehow related with the WebDropDown.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
