95
Z-index of fixed column below other columns (scroll over problem)
I recently updated a web project that was using 2007.3 UltraWebGrid and working fine..  I upgraded all the references to 2010.3 2134.   Since the upgrade everything is working pretty good with one exception.  We have a fixed column on all of the grids and the z-index appears to be messed up in IE 7 and above..  Everything appears fine at first until you scroll horrizontally, when you scroll all of the columns are moving over the fixed column instead of under the fixed column so you are unable to see the fixed column after you scroll.   It works properly in Firefox and IE 6 but does not work in IE7, 8, or 9
Any idea on what to look at for this?  I have been searching posts and have not seen anything that looks like my issue?
  • 8160
    Suggested Answer
    Hi pjaicher,
    sounds like something something with the styles is wrong. Can you try to create a new website drag a grid and replace your styles with these from this website. Do you have your own css styles. Maybe they affect the grid's style.
