585
Recurrence
Hi
I am looking at the sample and there is no recurrence as part of the example. Looking through the documentation on WebScheduleGenericDataProvider it says:
"The data model for WebSchedule has changed since the addition of WebScheduleGenericDataProvider. First thing you will notice is that the Recurrence table is removed and additional fields are added to the Activity and Resource table. The following table lists the required fields for the different types of data to function correctly in WebSchedule."
I want to create the tables in my own SQL Server database, using the default table names would be ok. Can you please offer some guidance as I am somewhat confused as I also want to implement the Recurrence functionality.
Thank you.
David
