going thru the documentation, it is not very clear as to what is the difference between few properties in the API. For example, considering Infragistic BoundDataFieldin webgrid or hierarchywebgrid what is the difference between DataFieldName and DataSourceField and Key?
Rather than just a simple vague line, I think a better documentation would lead to better usage of tool sets.
Are there any plans for future releases on WebHierarchyGrid.
Because of not sufficient documentation, we facing many errors with binding to N levels via custom POCO collections. Though there are examples online but all of them deal with accessdata binding via ASPX page. There is not enough examples to deal with POCO collection objects for HierarchyGrid.
Please make the WEB controls documentation more detailed and in depth like that of Windows Controls.There is a lot of comfort with windows controls than that of web controls.
Arif
Hello Imran,
Thank you for your reply.
The video related to the article above may be found at:
http://www.youtube.com/watch?v=1blIV17wQ_U&list=PLDAFFE8C757FED32E
Hope this helps. Please do not hesitate to contact me if you have any questions.
We are facing similar issues with POCO collections. The link above does not work anymore. Can you please us to code sample or the above article?
Thanks.
Hi Arif,
Thank you for you feedback. We appreciate that you took the time to convey your comments and I assure you that we consider our customer community comments very important to steering improvement at Infragistics
We strive to update our documentation in order to provide a comprehensive and accurate view of our products. Apart from the documentation and samples browser there are additional learning resources available through the forum blogs. You may find interesting information in the following article regarding using POCO collections:
http://blogs.infragistics.com/aspnet/articles/data-binding-the-webdatagrid-to-common-data-sources.aspx
Please feel free to contact me if you have any questions.
Best Regards,
Petar IvanovDeveloper Support EngineerInfragistics, Inc.http://ko.infragistics.com/support
