215
Re: How to change the behavior of the column header
I have a column that allows to Select All, how can I turn off the sorting on this checkbox column? BeforeSortChange does not appear on the list of the grid's events (Infragistics2.WebUI.UltraWebGrid.v6.3)
The actual code would be greatly appreciated.
This is the code:
 ///Header Select All functionality
    var oGrid;
    var cbSelectAll;
    function igrdInitializeLayout(object)
        oGrid = igtbl_getGridById(object);
        //need to set it here due to Infragistic's handling of columns.
        cbSelectAll = document.getElementById("cbSelectAll");
    function SelectAll(colIndex)
        var checked = cbSelectAll.checked;
        for (i = 0; i < oGrid.Rows.length; i++)
        oGrid.Rows.getRow(i).getCell(colIndex).setValue(checked);
    ///End of Header Select All functionality
                <igtbl:UltraWebGrid ID="grdPlans" runat="server" Width="100%" OnSortColumn="grdPlans_SortColumn"
                    DisplayLayout-RowAlternateStyleDefault-BackColor="#DDDDDD"
                    DisplayLayout-ClientSideEvents-InitializeLayoutHandler="igrdInitializeLayout">
                    <Bands>
                        <igtbl:UltraGridBand GroupByColumnsHidden="Yes" AllowSorting="OnClient">
                            <AddNewRow View="NotSet" Visible="NotSet">
                            </AddNewRow>
                            <Columns>
                                <igtbl:TemplatedColumn Key="Quote" Type="CheckBox" BaseColumnName="Quote" AllowUpdate="Yes" Width="25px" SortIndicator="Disabled">
                                <HeaderTemplate>
                                    <input id="cbSelectAll" name="cbSelectAll" type="checkbox" onclick="SelectAll(0)"   />
                                </HeaderTemplate>
                                </igtbl:TemplatedColumn>
                                <igtbl:UltraGridColumn BaseColumnName="PlanId" Hidden="True" Key="PlanId">
                                </igtbl:UltraGridColumn>
                                <igtbl:UltraGridColumn BaseColumnName="CarrierId" Hidden="True" Key="CarrierId">
                                    <Header>
                                        <RowLayoutColumnInfo OriginX="1" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="Carrier" HeaderText="Carrier" Key="Carrier"
                                    Width="100px" AllowUpdate="No">
                                    <CellStyle Wrap="True"></CellStyle>
                                    <Header Caption="Carrier">
                                        <RowLayoutColumnInfo OriginX="3" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="PlanType" HeaderText="Type" Key="PlanType"
                                    Width="50px" AllowUpdate="No">
                                    <Header Caption="Type">
                                        <RowLayoutColumnInfo OriginX="4" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="PlanTitle" HeaderText="Plan" Key="PlanTitle" Width="150px" AllowUpdate="No">
                                    <CellStyle Wrap="True" CssClass="newsLinksXSmall" Cursor="Hand">
                                    </CellStyle>
                                    <Header Caption="Plan">
                                        <RowLayoutColumnInfo OriginX="5" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="RAF" HeaderText="RAF" Key="RAF" Width="50px" AllowUpdate="No">
                                    <Header Caption="RAF">
                                        <RowLayoutColumnInfo OriginX="6" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="IsHPDF" Hidden="True" Key="IsHPDF">
                                    <Header>
                                        <RowLayoutColumnInfo OriginX="7" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="FileId" Hidden="true" Key="FileId">
                                    <Header>
                                        <RowLayoutColumnInfo OriginX="8" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="FileName" Hidden="true" Key="FileName">
                                    <Header>
                                        <RowLayoutColumnInfo OriginX="9" />
                                    </Header>
                                    <Footer>
                                    </Footer>
                                <igtbl:UltraGridColumn BaseColumnName="PlanTypeOrdinal" Hidden="True" Key="PlanTypeOrdinal">
                            </Columns>
                            <GroupByRowStyle BackColor="#7A96DF" BorderColor="Window" ForeColor="White" HorizontalAlign="Left">
                            </GroupByRowStyle>
                            <SelectedGroupByRowStyle BackColor="#7A96DF" BorderColor="Window" ForeColor="White"
                            </SelectedGroupByRowStyle>
                            <SelectedRowStyle BackColor="#7A96DF" BorderColor="Window" ForeColor="White" />
                            <RowExpAreaStyle BackColor="#7A96DF" BorderColor="Window" ForeColor="White" HorizontalAlign="Left">
                            </RowExpAreaStyle>
                            <RowSelectorStyle BackColor="#7A96DF">
                            </RowSelectorStyle>
                        </igtbl:UltraGridBand>
                    </Bands>
                    <DisplayLayout AllowColSizingDefault="Free" AllowUpdateDefault="Yes"
                        BorderCollapseDefault="Separate"
                        Name="grdPlans" RowHeightDefault="20px" RowSelectorsDefault="No" SelectTypeRowDefault="Extended"
                        StationaryMargins="Header" StationaryMarginsOutlookGroupBy="True" TableLayout="Fixed"
                        Version="4.00" ViewType="OutlookGroupBy" AutoGenerateColumns="False" GroupByColumnsHiddenDefault="No" JavaScriptFileName="/ig_common/scripts/ig_WebGrid.js" JavaScriptFileNameCommon="/ig_common/scripts/ig_shared.js"
                        EnableInternalRowsManagement="True" FixedColumnScrollType="Column" CellClickActionDefault="RowSelect" HeaderClickActionDefault="SortMulti">
                        <GroupByBox Hidden="True">
                            <Style BackColor="ActiveBorder" BorderColor="Window"></Style>
                        </GroupByBox>
                        <GroupByRowStyleDefault BackColor="#7A96DF" BorderColor="Window" Font-Bold="True" Height="12px" ForeColor="White">
                        </GroupByRowStyleDefault>
                        <FooterStyleDefault BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                            <BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px" WidthTop="1px" />
                        </FooterStyleDefault>
                        <RowStyleDefault BackColor="Window" BorderColor="Silver" BorderStyle="Solid" BorderWidth="1px">
                            <BorderDetails ColorLeft="Window" ColorTop="Window" />
                            <Padding Left="3px" />
                        </RowStyleDefault>
                        <HeaderStyleDefault BackColor="#7A96DF" BorderStyle="Solid" ForeColor="White" HorizontalAlign="Center" Cursor="Hand" Wrap="True">
                        </HeaderStyleDefault>
                        <EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
                        </EditCellStyleDefault>
                        <FrameStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid"
                            BorderWidth="1px" Font-Names="Microsoft Sans Serif" Font-Size="8pt" Width="100%" TextOverflow="Ellipsis" Wrap="True">
                        </FrameStyle>
                        <Pager MinimumPagesForDisplay="2">
                            <Style BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px">
                                <BorderDetails ColorTop="White" WidthLeft="1px" WidthTop="1px" ColorLeft="White"></BorderDetails>
                                </Style>
                        </Pager>
                        <AddNewBox>
                            <Style BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid" BorderWidth="1px">
                                </Style>
                        </AddNewBox>
                        <RowExpAreaStyleDefault BackColor="#7A96DF" BorderColor="Window" ForeColor="White">
                        </RowExpAreaStyleDefault>
                        <SelectedGroupByRowStyleDefault BackColor="#7A96DF" BorderColor="Window" ForeColor="White">
                        </SelectedGroupByRowStyleDefault>
                        <RowSelectorStyleDefault BackColor="#7A96DF">
                        </RowSelectorStyleDefault>
                        <ClientSideEvents CellClickHandler="grdPlans_CellClickHandler" ColumnHeaderClickHandler="grdPlans_ColumnHeaderClickHandler" />
                    </DisplayLayout>
                </igtbl:UltraWebGrid>
  • 49378
    Hi alokazia,
    It has been some time since your post, however in case you still need assistance I would be glad to help.
    Sorting for a particulart UltraWebGrid column may be disabled by setting the SortingIndicator property to Disabled. For instance:
                        <igtbl:UltraGridColumn SortIndicator="Disabled">
                            <Header>
                            </Header>
                            <Footer>
                            </Footer>
    Please note that the UltraWebGrid control is now outdated and as of .NetAdvantage 2011 Volume 2 is no longer included in our product package. I would suggest that you consider switching to the WebDataGrid/WebHieararchicalDataGrid. More information regarding these controls is available at:
    http://help.infragistics.com/NetAdvantage/ASPNET/2011.2/CLR4.0/?page=Web_WebDataGrid_WebDataGrid.html
    Additional samples demonstrating the features of these grids can be found at:
    http://samples.infragistics.com/aspnet/
    Feel free to contact me if you have any questions.
