I recently posted a question to the forum in regards to this issue, I haven't heard anything back from the Infragistics team yet. Could someone help me with this issue? It would be much appreciated.
I have a web page with a menu (v10.2.20102.2102) and a content iframe. Since the upgrade of the menu from "ultra web menu" to the "web data menu", the menus do not show properly when the content frame points to a pdf document. It appears that the new menu has a lower z-index, showing the sub menus behind the frame. I was wondering if anyone has reported this issue and if there is any work around this. Thanks in advance.
Below is the source code.
<%@ Page Language="C#" AutoEventWireup="true" CodeBehind="WebForm1.aspx.cs" Inherits="WebForm1" %>
<%@ Register Assembly="Infragistics4.Web.v10.2, Version=10.2.20102.2101, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Namespace="Infragistics.Web.UI.NavigationControls" TagPrefix="ig" %>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head runat="server">
<title></title>
</head>
<body>
<form id="form1" runat="server">
<asp:ScriptManager ID="ScriptManager1" runat="server"></asp:ScriptManager>
<!-- Infragistics Web Data Menu Begins -->
<ig:WebDataMenu ID="menuNavigationHeader" runat="server" Width="100%" Height="30px"
GroupSettings-Orientation="Horizontal" SubMenuOpeningDelay="1000"
SubMenuClosingDelay="0">
<GroupSettings Orientation="Horizontal" enableanimation="False"></GroupSettings>
<Items>
<ig:DataMenuItem Text="hello">
<ig:DataMenuItem Text="test 1"></ig:DataMenuItem>
</Items>
</ig:DataMenuItem>
</ig:WebDataMenu>
<!-- Content Frame Begins -->
<iframe id="contentIFrame" frameborder="0" src="/data/general/pe_multiples.pdf" width="100%" height="100px" scrolling="yes"></iframe>
</form>
</body>
</html>
I know this is an old issue; however, we are upgrading from 11.1 to 13.2 and have just experienced this exact issue where the WebDataMenu appears behind Adobe Reader plugin. We must support IE9 and IE11. This did not use to happen (even in the same browsers) with WebUltraMenu 11.1.
Hi Troy,
I was just wondering if you got a chance to try my code (attached in previous reply)? Thanks.
Thanks for helping me with the issue. I tried your example, but the parts of the menu still get hidden behind the PDF document. Attached you will find a screen shot and source code.
Regards.
Hi Manuel,
Attached is a demo that you can reference that implements the work-around. When you have a moment, give this a look as it fixes the Z-Index issue in IE7.
We use IE 7. The proposed solution, unfortunately, did not solve my problem. The menu still appears hidden when the content page holds a pdf document. Do you have any other suggestions?
Thanks.
