295
ItemTemplate ImageButton CommandArgument
I have a WHDG that is bound to a dataset and has one TemplateDataField and one ItemTemplate with an ImageButton. I am setting the CommandArgument of the ImageButton to the value of a column in my data source. I can set it to any column in that dataset except the column that is referenced in the DataKeyFields property of the grid. When I use that column, which is the primary key of the dataset, the CommandArgument that I get server side is a negative (-) number and is not the proper value of that record. It appears to be the index of the row that contains the imagebutton.
Server Side Handler
protected
void btnGoClientDetails_Command(object sender, EventArgs e)
ImageButton img = (ImageButton)sender;
int WorkItemPCNId = 0;
if (img != null){
WorkItemPCNId =
Convert.ToInt32(img.CommandArgument);
Grid code
ig:WebHierarchicalDataGrid ID="PCNGrid" runat="server" Height="700px" Width="1100px"
AutoGenerateBands="False"
AutoGenerateColumns="False" DataMember="ObjectDataSource1_DefaultView"
DataSourceID="WebHierarchicalDataSource1" Key="ObjectDataSource1_DefaultView"
OnDataBound="PCNGrid_DataBound" DataKeyFields="WorkItemPCNID" >
<Columns
<ig:BoundDataField DataFieldName="WorkItemPCNID" Key="WorkItemPCNID" Hidden
="true">
<Header Text="WorkItemPCNID"
</ig:BoundDataField
<ig:BoundDataField DataFieldName="SourcePCNId" Key="SourcePCNId" Hidden
="true">
<Header Text="SourcePCNId"
</ig:BoundDataField
<ig:TemplateDataField Key="SelectRow" Hidden="false" Width
="30px">
<ItemTemplate
<asp:ImageButton ID="btnGoClientDetails" runat="server" ImageUrl="~/images/ViewDetails.gif" ToolTip="View Details In PIMs Database"
OnCommand="btnGoClientDetails_Command" CommandArgument='<%# Eval("WorkItemPCNID")%>'
</ItemTemplate
<Header Text=""
</ig:TemplateDataField
  • 295
    Figured it out myself. Was a problem with the dataset. Not the grid.
