My Webdropdown ContainerWidth = "600px", but the paging width is around 200px, how I can increase page section width also to 600px.
Krishna.
Hi Deni Vangjeli
I am using webdropdown and Paging.Enabled=True . However when Page number in clicked within the webdropdown, it showing some selection in the text field . Please provide me a solution for this .
-- Shantesh
I'm glad you fixed it,
Have a good day!
Deni,
Sorry it was mistake, I found what was causing the issue. I have the following style on my page and I haven't noticed it. I copied lots of code from samples, that's why all this issues coming up. By removing this style it is working fine now.
style type="text/css">
.igdd_Pager
width: 190px;
</style>
I appreciate your time so much.
here is the .aspx code:
<ig:WebDropDown runat="server" ID="ddlEquipment" StyleSetName="Default" Enabled="false" OnPreRender="ddlEquipment_PreRender" EnableAutoCompleteFirstMatch="false" EnableViewState="false" EnableAutoFiltering="Server" AutoFilterQueryType="Contains" TextField="EquipmentName" ValueField="equipmentID" PageSize="10" EnablePaging="true" Width="600px" DropDownContainerWidth="600px" DropDownContainerHeight="300px"></ig:WebDropDown>
The datasource is a DataTable, it is from code behind. which looks like follwoing. (Never mind this is a test code that's why i have in-line sql)
private void DataBindEquipmentDropDown() { this.ddlEquipment.Items.Clear();
DataTable table = null;
if (!String.IsNullOrEmpty(this.PlantSymbol) && !String.IsNullOrEmpty(this.Unit)) { using (AseConnection conn = Common.DataSource.GetWorkManagementConnection()) { using (AseCommand cmd = conn.CreateCommand()) { cmd.CommandText = "SELECT sys.tx_sys AS system_name, cp.tx_cmpt AS comp_name, equipment.id_mpac_eqp_tag AS equipmentID, equipment.tx_equip_desc AS equipment_name FROM oper..mpa_eqpt equipment LEFT OUTER JOIN oper..pmr_sys sys ON equipment.id_sys = sys.id_sys LEFT OUTER JOIN oper..pmr_comp cp ON cp.id_cmpt_type = equipment.id_cmpt_type WHERE equipment.id_cmpt IS NOT NULL AND equipment.id_cmpt_type IS NOT NULL AND cp.id_cmpt = 0 AND equipment.cd_plnt_symb = @PlantSymb AND equipment.cd_unit = @Unit AND (CASE WHEN @SubUnit IS NULL THEN 1 WHEN @SubUnit = equipment.cd_component THEN 1 ELSE 0 END) = 1 AND (CASE WHEN @System = -1 THEN 1 WHEN @System = equipment.id_sys THEN 1 ELSE 0 END) = 1 AND (CASE WHEN @ComponentType = -1 THEN 1 WHEN @ComponentType = equipment.id_cmpt_type THEN 1 ELSE 0 END) = 1"; cmd.Parameters.Add("@PlantSymb", AseDbType.VarChar, 3).Value = this.PlantSymbol; cmd.Parameters.Add("@Unit", AseDbType.VarChar, 2).Value = this.Unit; cmd.Parameters.Add("@SubUnit", AseDbType.VarChar, 2).Value = this.SubUnit;
if (this.System == 0 && this.Component == 0) { cmd.Parameters.Add("@System", AseDbType.Integer).Value = 0; cmd.Parameters.Add("@ComponentType", AseDbType.Integer).Value = 0; } else {
if (this.System > 0) cmd.Parameters.Add("@System", AseDbType.Integer).Value = this.System; else cmd.Parameters.Add("@System", AseDbType.Integer).Value = -1;
if (this.Component > 0) cmd.Parameters.Add("@ComponentType", AseDbType.Integer).Value = this.Component; else cmd.Parameters.Add("@ComponentType", AseDbType.Integer).Value = -1; }
table = Common.DataSource.GetDataTable(cmd); } } }
table.Columns.Add("EquipmentName", typeof(String));
if (table != null && table.Rows.Count > 0) {
foreach (DataRow row in table.Rows) { row["EquipmentName"] = String.Format("{0} / {1} / {2} / {3}", Common.GetDefault(row["system_name"], ""), Common.GetDefault(row["comp_name"], ""), Common.GetDefault(row["equipment_name"], ""), Common.GetDefault(row["equipmentID"], "")); }
DataRow row3 = table.NewRow(); row3["EquipmentName"] = "Equipment Not Found"; row3["equipmentID"] = String.Format("{0}{1}{2}0000", this.PlantSymbol, this.Unit, (String.IsNullOrEmpty(this.SubUnit) ? "00" : this.SubUnit)); table.Rows.InsertAt(row3, 0);
this.ddlEquipment.Enabled = true;
this.ddlEquipment.DataSource = table; this.ddlEquipment.DataBind(); }
The following is the css file, i am using(ig_dropDown.css)
Main control CSS class
.igdd_Control
Main Control CSS class when it's disabled
.igdd_ControlDisabled
Main control css class on hover
.igdd_ControlHover
.igdd_ControlFocus
.igdd_ControlArea
CSS class for the actual input field (<input type="text" />)
.igdd_ValueDisplay
.igdd_ValueDisplayHover
.igdd_ValueDisplayFocus
.igdd_ValueDisplayDisabled
.igdd_ValueDisplayReadOnly
.igdd_DropDownList
.igdd_DropDownListHover
.igdd_DropDownListReadOnly
.igdd_DropDownListContainer
.igdd_DropDownListContainerHover
.igdd_DropDownButton
.igdd_DropDownButtonHover
CSS class that controls the style of the LI items in the list
.igdd_ListItem
.igdd_ListItemActive
.igdd_ListItemHover
.igdd_ListItemSelected
.igdd_ListItemDisabled
Applied to the whole pager
Loading message container
.igdd_LoadingItemsMessage
Styles the current page link only
.igdd_PageCurrent
Styles all page links in general
.igdd_PageLink
a:active
.igdd_DropDownButtonDisabled
.igdd_NullText
a:hover
a:visited
.igdd_DropDownListContainerFocus
Styling for anchor when hovered anywhere on ListItem
a:link
.igdd_ListItemFocus
CSS class for the table that accomodates the value display and the drop down button, and which is a
child of the main control (div)
.igdd_ValueDisplayTable
For Disabled=True of a DropDownItem
.igdd_DropDownButtonFocus
.igdd_DropDownListFocus
pseudo class used so Value Display input does not have focus
glow in some browsers like GoogleChrome or AppleSafari
input:focus
.igdd_DropDownListDisabled
Krishna, can you please provide the ASP code for the<ig:WebDropDown> that you are using here? This problem doesn't happen at least if you bind it to a SQL Database. Btw, in what form is the list data?
