I do not get it why plain text file have the each column on every line, not on one line, then move to the next row????
PDF and XPS will show what it should look like in the grid, but text file, i will like it to be able to look like this in my text file.
for example:
12312333, ,01/23/2011, New York Corp, 1234
1445442, P-, 01/24/2011, Belfast Corp., 21344
Hello robkapsig,
Your solution will be helpful to other users that need similar functionality.
Thank you for your feedback.
I solve the problem by using different sections. You cannot have the same section for the other data.
for example, my report only have one section before, now i have section1, section 2 now. It work better that way.
Can you send me an example of the grid that you are trying to export as plain text in order to test this behavior myself?
If you cannot provide me a working sample you can give me information about your Infragistics controls version, Visual Studio version and description of the grid (or table) that you want to export.
I am waiting for your response.
