i get this error when i Bind an WebDataGrid, this grid fills with a dataset .. this dataset provides a property called Detalle, but when i rebind many times with a new DataSet, the application fails and display this error.DataBinding: 'Infragistics.Web.UI.GridControls.GridRecordItem' does not contain a property with the name 'Detalle'Below my code ASPX.. anybody knows what happen here?
ASPX Code:
visible='<%# esVisible((DataBinder.Eval(((Infragistics.Web.UI.TemplateContainer)Container).DataItem, "Detalle"))%>'
CS code:
private bool esVisible(object isVisible) { if ((int)isVisible == 1) { return true; } return false; }
Regards.Alfredo Melo xD
ahm better translation :D..
thats exactly what i did with the dataset, but the error dissapeared, also i checked my webDatagrid, but i couldn't find anything.. anyways :) thanks for your response vivian.
Hi Vivian!
thats exactly what i did with the dataset, but the error dissapeared, also i checked of my webDatagrid, but i cant found anything.. anyways :) thanks for your response vivian.
Regards!
Alfredo Melo
Hello Alfredo Melo,
I suggest checking the dataset that is causing the error. You may have to verify if the property exists in the dataset.
If you have any questions, please let me know.
